Menu Navigation
Below is a listing of general specifications for the 1976 Corvette including, engine, exhaust and more.
Wheelbase (in.) 98.0
Track Frt/Rear (in) 58.7 / 59.5
Length (in.) 185.2
Width (in.) 69.0
Height (in.) 48.1
Frontal Area (in) NA
Ground Clearance (in.) (minimum) 4.4
Curb Weight (lbs) 3610
Weight-to-power ratio (lbs:hp) 17.8:1
Coefficient of Drag NA
Weight Dist. F/R (%) 51.1 / 48.9
Coolant Capacity (qt.) NA
Fuel Capacity (gal.) 17.0
Oil Capacity (qt.) (w/ filter) NA
Engine Specifications
  L48 L82
Type OHV, cast iron block/heads, 350 ci, pushrod V8, 2 valves/cylinder
Bore NA 4.00 in
Stroke NA 3.48 in
Displacement 350 ci. 350 ci.
Compression Ratio NA 9.0:1
Horsepower 180 hp 210 hp @ 5200 rpm
Torque NA 255 lb-ft @ 3600 rpm
Redline (RPM) 5300 NA
Induction System 1 x 4 bbl Rochester 1 x 4 bbl Rochester
Valvetrain NA NA
Miscellaneous
Brakes
Type Vented disc F/R
Front Rotors (diam x thickness) 11.75 in.
Rear Rotors (diam x thickness) 11.75 in.
Wheels and Tires
Wheel Size 8.0 x 15 in.
Wheel Type Cast alloy
Tire Make/Size Firestone steel radial 500, GR70-15
Transmission
  Automatic Manual
Type 3-Speed Automatic 4-Speed Manual
Gear Ratios
1st 2.48 2.43
2nd 1.48 1.61
3rd 1.00 1.23
4th NA 1.00
Reverse NA NA
Axle Ratio NA NA
Final Drive Ratio 3.36 3.55
