1999 C5 Corvette |
1999 C5-R Corvette |
| Structure/Frame |
Steel welded perimeter frame with hydro- formed frame rails |
| Body |
Fiberglass-reinforced |
Carbon fiber
plastic |
| Front Suspension |
Short/long arm double wishbone; forged aluminum control arms; transverse leaf spring; gas shocks; 23.0mm anti-roll bar (25.4mm w/hardtop or Z51 pkg.) |
wishbone; forged
aluminum upper, cast
aluminum lower control
arms; fabricated steel
knuckle; coil-over
multi-adj. shocks;
adj. anti-roll bar |
| Rear Suspension |
Short/long arm double wishbone; cast aluminum control arms; composite transverse leaf spring with individual height adjusters; gas shocks; 19.1mm anti-roll bar |
wishbone; steel
fabricated upper, cast
knuckle; coil-over
multi-adj. shocks;
adj. anti-roll bar
(27.1 w/hardtop or Z51
pkg.) |
| Front Tires/Wheels |
P245/45ZR-17 Goodyear
Eagle F-1 high performance Extended Mobility (EMT)/17" X 8.5" 5-spoke aluminum |
Goodyear Racing Eagle
25X10-18
BBS forged magnesium 1
piece center lock
wheel |
| Rear Tires/Wheels |
P275/40ZR-18 Goodyear
Eagle F-1 high performance Extended Mobility (EMT)/18" X 9.5" 5-spoke aluminum |
28X12.5-18
piece center lock
wheel |
1999 C5 Corvette |
| Brakes Type |
4-wheel vented disc w/standard ABS |
4-wheel vented Alcon disc |
| Front Rotor Diameter/Thickness |
12.6"/1.26" |
15.0"/1.38" |
| Rear Rotor Diameter/Thickness |
11.8"/1.0" |
14.0"/1.26" |
| Total Swept Area in. Front/Rear in. |
263 sq. in./158 sq. |
343 sq. in./292 sq. |
| Engine Type |
LS1 Pushrod V8 with aluminum block and heads |
LS1 Pushrod V8 with
aluminum block and
heads |
| Bore X |
3.90" X 3.62"/5.67 |
4.125" X 3.42"/5.98 |
| Stroke/Displacement |
liters (346 cid) |
liters (365 cid) |
| Intake System |
Electronic Sequential Fuel Injection |
| Ignition |
Distributorless - one coil per cylinder |
GEN III Delphi |
| Valvetrain |
Two pushrod-operated valves per cylinder |
Modified stock cam; aftermarket rocker arms |
| Compression Ratio |
10.1:1 |
12.5:1 |
| Horsepower |
345 @ 5600 RPM |
600 @ 7200 RPM |
| Torque |
350 @ 4400 RPM |
495 @ 5600 RPM |
| Transmission Type |
6-speed manual (coupe & hardtop) 4-speed 4L60-E automatic overdrive |
5-speed manual with
drop gear
(convertible) |
| Final drive ratio |
3.42:1 (w/6-spd.) 2.73:1 (w/auto, 3.15:1 opt. w/auto) |
3.11:1 (subject to
change depending on
race track) |
Performance measurements for the C5-R Corvette are not available. The
car is set up differently for different tracks to optimize lap times.
