Below is a listing of specifications from Chevrolet for the 2006 Corvette and Z06 including engine, chassis, suspension, transmission and more.
Source: GM Media
Overview |
Models: |
Chevrolet Corvette coupe and 2006 Corvette Z06 |
Body styles / driveline: |
2-door hatchback coupe with removable roof; rear-wheel drive (coupe); 2-door hatchback coupe with fixed roof; rear-drive (Z06) |
Construction: |
composite body panels, hydroformed steel frame with aluminum and magnesium structural and chassis components (coupe); composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components (Z06) |
Manufacturing location: |
Bowling Green, Kentucky |
Engines |
6.0L V-8 LS2 |
7.0L V-8 LS7 |
Displacement (cu in / cc): |
364 / 5967 |
427 / 7011.3 |
Bore & stroke (in / mm): |
4 x 3.62 / 101.6 x 92 |
4.125 x 4 / 104.8 x 101.6 |
Block material: |
cast aluminum |
cast aluminum |
Cylinder head material: |
cast aluminum |
cast aluminum |
Valvetrain: |
OHV, 2 valves per cylinder |
Fuel delivery: |
SFI (sequential fuel injection) |
Compression ratio: |
10.9:1 |
11:1 |
Horsepower |
400 / 298 @ 6000 |
500 / 373 @ 6200 |
Torque (lb-ft / Nm @ rpm): |
400 / 542 @ 4400 |
475 / 657 @ 4800 |
Recommended fuel: |
93 octane (recommended but not required) |
93 octane |
Estimated fuel economy (mpg city / hwy / combined): |
automatic: 18 / 25 / 21 manual: 19 / 28 / 23 |
TBD |
Transmissions |
6-speed manual |
6-speed manual, w/ optional Z51 Performance Package |
6-speed paddle-shift automatic |
Application: |
std |
opt |
opt |
Gear ratios (:1): |
First: |
2.66 |
2.97 |
4.02 |
Second: |
1.78 |
2.07 |
2.36 |
Third: |
1.30 |
1.43 |
1.53 |
Fourth: |
1.00 |
1.00 |
1.15 |
Fifth: |
0.74 |
0.71 |
0.85 |
Sixth: |
0.50 |
0.57 |
0.67 |
Reverse: |
2.90 |
3.28 |
3.06 |
Final drive ratio: |
3.42 |
3.42 |
2.56 |
Chassis / Suspension |
Coupe and Convertible |
Z06 |
Front: |
short/long arm ( SLA ) double wishbone, cast aluminum upper & lower control arms, transverse-mounted composite leaf spring, monotube shock absorber |
Rear: |
Traction control: |
electronic traction control; Active Handling |
Brakes |
Z06 |
Type: |
front and rear power-assisted disc with ABS; cross-drilled rotors with Z51 package |
front and rear power-assisted disc with ABS with 6-piston front and 4-piston rear calipers, cross-drilled rotors |
Rotor diameter x thickness (in / mm): |
front: 12.8 x 1.26 / 325 x 32 rear: 12 x 1 / 305 x 26; Z51 Performance Package: front: 13.4 x 1.26 / 340 x 32 rear: 13 x 1 / 330 x 26 |
front: 14 x 1.3 / 355 x 32 |
Wheels & Tires |
Wheel size: |
front: 18 inch x 8.5 inch rear: 19 inch x 10 inch |
front: 18 inch x 9.5 inch rear: 19 inch x 12 inch |
Tires: |
Goodyear Eagle F1 Supercar (w/Z51) Extended Mobility front: P245/40ZR18 rear: P285/35ZR19 |
Goodyear Eagle F1 Supercar Extended Mobility |
Dimensions |
Z06 |
Wheelbase (in / mm): |
105.7 / 2685 |
105.7 / 2685 |
Overall length (in / mm): |
174.6 / 4435 |
175.6 / 4460 |
Overall width (in / mm): |
72.6 / 1844 |
75.9 / 1928 |
Overall height (in / mm): |
49 / 1244 |
49 / 1244 |
Curb weight (lb / kg): |
Coupe: 3179 / 1442 Conv.: 3199 / 1451 |
3130 / 1419.7 |
Interior |
Seating capacity |
2 |
Interior volume (cu ft / L): |
52 / 1475 (all models) |
Headroom (in / mm): |
38 / 962 (all models) |
Legroom (in / mm): |
43 / 1092 (all models) |
Shoulder room (in / mm): |
55 / 1397 (all models) |
Hip room (in / mm): |
54 / 1371 (all models) |
Capacities |
Cargo volume |
Coupe and Z06: 22 / 634 Convertible: 11 / 295 (top up); 5 / 144 (top down) |
Fuel tank (gal / L): |
18 / 68.1 |
Engine oil (qt / L): |
Coupe and Convertible: 5.5 / 5.2 Z06: 8 / 7.5 |
* Horsepower and torque SAE certified. A new voluntary power and torque certification procedure developed by the SAE Engine Test Code committee was approved March 31, 2005. This procedure (J2723) ensures fair, accurate ratings for horsepower and torque by allowing manufacturers to certify their engines through third-party witness testing. GM was the first auto manufacturer to begin using the procedure and expects to use it for all newly rated engines in the future.
