Below is a listing of specifications for the 2009 Corvette coupe, convertible and Z06.
Overview |
Models: |
Chevrolet Corvette Coupe, Convertible and Z06 |
Body styles / driveline: |
two-door hatchback coupe with removable roof; rear-wheel drive (Coupe and Convertible) two-door hatchback coupe with fixed roof; rear-wheel drive (Z06) |
Construction: |
composite body panels, hydroformed steel frame with aluminum and magnesium structural and chassis components (coupe); composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components (Z06) |
Manufacturing location: |
Bowling Green, Ky. |
6.2L V-8 LS3 |
7.0L V-8 LS7 (Z06) |
Displacement (cu in / cc): |
376 / 6162 |
427.6 / 7008 |
Bore & stroke (in / mm): |
4.06 x 3.62 / 103.25 x 92 |
4.125 x 4 / 104.8 x 101.6 |
Block material: |
cast aluminum |
cast aluminum |
Cylinder head material: |
cast aluminum |
cast aluminum |
Valvetrain: |
overhead valve, two valves per cylinder |
Fuel delivery: |
SFI (sequential fuel injection) |
Compression ratio: |
10.7:1 |
11:1 |
Horsepower |
430 / 321 @ 5900* w/ std. exhaust 436 / 325 @ 5900* w/ opt. exhaust |
505 / 377 @ 6300* |
Torque (lb-ft / Nm @ rpm): |
424 / 575 @ 4600* w/ std. exhaust |
470 / 637 @ 4800* |
Recommended fuel: |
premium recommended but not required |
premium required |
EPA estimated fuel economy (city / hwy): |
15 / 25 (automatic) |
15 / 24 (manual) |
six-speed manual; Base and Z06 |
six-speed manual, w/ opt. Z51 Performance Package |
six-speed paddle-shift automatic |
Application: |
std |
opt |
opt |
Gear ratios (:1): |
First: |
2.66 |
2.97 |
4.03 |
Second: |
1.78 |
2.07 |
2.36 |
Third: |
1.30 |
1.43 |
1.53 |
Fourth: |
1.00 |
1.00 |
1.15 |
Fifth: |
0.74 |
0.71 |
0.85 |
Sixth: |
0.50 |
0.57 |
0.67 |
Reverse: |
2.90 |
3.28 |
3.06 |
Final drive ratio: |
3.42 |
3.42 |
2.56 |
Coupe and Convertible |
Z06 |
Front: |
short/long arm ( SLA) double wishbone, cast aluminum upper & lower control arms, transverse-mounted composite leaf spring, monotube shock absorber |
Rear: |
Traction control: |
electronic traction control; Active Handling |
Z06 |
Type: |
front and rear power-assisted disc with ABS; cross-drilled rotors with Z51 package and Magnetic Ride Control |
front and rear power-assisted disc with ABS with six-piston front and four-piston rear calipers, cross-drilled rotors |
Rotor diameter x thickness (in / mm): |
front: 12.8 x 1.26 / 325 x 32 |
front: 14 x 1.3 / 355 x 32 |
Wheels & Tires |
Wheel size: |
front: 18-inch x 8.5-inch rear: 19-inch x 10-inch |
front: 18-inch x 9.5-inch rear: 19-inch x 12-inch |
Tires: |
Goodyear Eagle F1 Supercar (w/Z51) |
Goodyear Eagle F1 Supercar Extended Mobility |
Z06 |
Wheelbase (in / mm): |
105.7 / 2685 |
105.7 / 2685 |
Overall length (in / mm): |
174.6 / 4435 |
175.6 / 4460 |
Overall width (in / mm): |
72.6 / 1844 |
75.9 / 1928 |
Overall height (in / mm): |
49 / 1244 |
49 / 1244 |
Curb weight (lb / kg): |
Coupe: 3217 / 1459 Conv.: 3222 / 1461 |
3180 / 1442 |
Interior |
Seating capacity |
2 |
Interior volume (cu ft / L): |
52 / 1475 (all models) |
Headroom (in / mm): |
38 / 962 (all models) |
Legroom (in / mm): |
43 / 1092 (all models) |
Shoulder room (in / mm): |
55 / 1397 (all models) |
Hip room (in / mm): |
54 / 1371 (all models) |
Capacities |
Cargo volume |
Coupe and Z06: 22 / 634 |
Fuel tank (gal / L): |
18 / 68.1 |
Engine oil (qt / L): |
Coupe and Convertible: 5.5 / 5.2 |
* SAE certified.
