Below is a listing of general specifications for the 2010 Corvette LS3 engine.
| LS3 6.2L V8 ENGINE SPECIFICATIONS | |
| Engine type | Overhead Valves (2 valves per cylinder) |
| Piston displacement, cu. in.(liter) | 378.3 (6.20) |
| Bore and stroke, in.(cm.) | 4.06 x 3.62 (10.31 x 9.19) |
| Compression ratio | 10.7:1 |
| Exhaust - single | All |
| Horsepower | 430@5900 rpm |
| Kilowatts(kW) | 320.78@5900 rpm |
| Torque (lb.-ft.) | 424@4600 rpm |
| Newton - Meters (N-m) | 572.40@4600 rpm |
