Menu Navigation
2012 Corvette Specifications - Base Model and Grand Sport
Below are specifications of the 2012 Corvette base model and Grand Sport including dimensions, engine, transmission, brakes, wheels and more.
Source:  GM Media
Model Lineup | Overview | Engines | Transmission | Chassis/Suspension | Brakes | Wheels/Tires | Dimensions | Capacities
Overview
Models:
Chevrolet Corvette coupe, convertible and Grand Sport coupe, convertible
Body styles / driveline:
two-door hatchback coupe with removable roof or convertible; rear-wheel drive
Construction:
composite body panels, hydroformed steel frame with aluminum and magnesium structural and chassis components
Manufacturing location:
Bowling Green, Ky.
Back to top
Engines
6.2L V-8 LS3
Displacement (cu in / cc):
376 / 6162
Bore & stroke
(in / mm):
4.06 x 3.62 / 103.25 x 92
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
overhead valve, two valves per cylinder
Fuel delivery:
SFI (sequential fuel injection)
Lubrication system
dry sump system on the Grand Sport Manual Coupe
Compression ratio:
10.7:1
Horsepower
(hp / kW @ rpm):
430 / 321 @ 5900* w/ std. exhaust
436 / 325 @ 5900* w/ opt. exhaust
Torque
(lb-ft / Nm @ rpm):
424 / 575 @ 4600* w/ std. exhaust
428 / 580 @ 4600* w/ opt. exhaust
Recommended fuel:
premium recommended, not required
EPA estimated fuel economy
(city / hwy):
15 / 25 (automatic)
16 / 26 (manual)
Back to top
Transmission
Transmissions
six-speed
manual
six-speed paddle-shift automatic
Application:
std.
opt.
Gear ratios (:1):
First:
2.66
4.03
Second:
1.78
2.36
Third:
1.30
1.53
Fourth:
1.00
1.15
Fifth:
0.74
0.85
Sixth:
0.50
0.67
Reverse:
2.90
3.06
Final drive ratio:
3.42
2.56
Back to top
Chassis/Suspension
Corvette Grand Sport
Front:
short/long arm ( SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber
Rear:
Traction control:
electronic traction control;
Active Handling
electronic traction control; Active Handling
Back to top
Brakes
Type:
front and rear power-assisted disc with ABS
front and rear power-assisted disc with ABS with six-piston front and four-piston rear calipers, cross-drilled rotors
Rotor diameter x thickness (in / mm):
front: 12.8 x 1.26 / 325 x 32 (std.); 13.4 x 1.26 / 340 x 32 (w/ Magnetic Ride Control)
rear: 12 x 1 / 305 x 26; (std.); 13 x 1 / 330 x 26 (w/ Magnetic Ride Control)
front: 14 x 1.3 / 355 x 32
rear: 13.4 x 1 / 340 x 26
Brake swept area (sq in / mm):
front: 274 / 1768
rear: 200 / 1290
front: 309 / 1994
rear: 269 / 1735
Wheels & Tires
Wheel size:
front: 18-inch x 8.5-inch
rear: 19-inch x 10-inch
front: 18-inch x 9.5-inch
rear: 19-inch x 12-inch
Tires:
front: P245/40ZR18
rear: P285/35ZR19
front: P275/35ZR18
rear: P325/30ZR19
Back to top
Wheels/Tires
Wheel size:
Tires:
front: P245/40ZR18
rear: P285/35ZR19
front: P275/35ZR18
rear: P325/30ZR19
Back to top
Exterior
Wheelbase (in / mm):
105.7 / 2685
105.7 / 2685
Overall length (in / mm):
174.6 / 4435
175.6 / 4460
Overall width (in / mm):
72.6 / 1844
75.9 / 1928
Overall height (in / mm):
49 / 1244
48.7 / 1236
Curb weight (lb / kg):
3208 / 1455 (coupe)
3221 / 1461 (convertible)
3311 / 1502 (coupe)
3289 / 1492 (convertible)
Weight distribution
(% front / rear):
51 / 49
51 / 49
Interior
Seating capacity
2
Interior volume (cu ft / L):
52 / 1475 (all models)
Headroom (in / mm):
38 / 962 (all models)
Legroom (in / mm):
43 / 1092 (all models)
Shoulder room (in / mm):
55 / 1397 (all models)
Hip room (in / mm):
54 / 1371 (all models)
Back to top
Capacities
Cargo volume
(cu ft / L):
Coupe and Z06: 22 / 634
Convertible: 11 / 295 (top up); 7.5 / 212 (top down)
Fuel tank (gal / L):
18 / 68.1
Engine oil (qt / L):
5.5 / 5.2
Back to top
* SAE certified.
