Below are specifications of the 2012 Corvette Z06 including dimensions, engine, transmission, brakes, wheels and more.
Source: GM Media
Overview |
Models: |
Chevrolet Corvette Z06 |
Body styles / driveline: |
two-door hatchback coupe with fixed roof; rear-wheel drive |
Construction: |
composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components |
Manufacturing location: |
Bowling Green, Ky. |
Engines |
7.0L V-8 LS7 (Z06) |
Displacement (cu in / cc): |
427 / 7008 |
Bore & stroke (in / mm): |
4.125 x 4 / 104.8 x 101.6 |
Block material: |
cast aluminum |
Cylinder head material: |
cast aluminum |
Valvetrain: |
overhead valve, two valves per cylinder |
Fuel delivery: |
SFI (sequential fuel injection) |
Compression ratio: |
11.0:1 |
Horsepower |
505 / 377 @ 6300* |
Torque (lb-ft / Nm @ rpm): |
470 / 637 @ 4800* |
Recommended fuel: |
premium required |
EPA estimated fuel economy (city / hwy): |
15 / 24 (manual) |
Transmission |
six-speed manual |
Application: |
std. |
Gear ratios (:1): |
First: |
2.66 |
Second: |
1.78 |
Third: |
1.30 |
Fourth: |
1.00 |
Fifth: |
0.74 |
Sixth: |
0.50 |
Reverse: |
2.90 |
Final drive ratio: |
3.42 |
| Chassis / Suspension |
Front: |
short/long arm (SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber; Magnetic Ride Control w/ Z07 pkg. |
Rear: |
Traction control: |
electronic traction control; Active Handling |
Brakes |
Type: |
front and rear power-assisted disc with ABS with six-piston front and four-piston rear calipers, cross-drilled rotors; ceramic rotors w/ Z07 pkg. |
Rotor diameter x thickness (in / mm): |
front: 14 x 1.3 / 355 x 32 |
Brake swept area (sq in / mm): |
front: 309 / 1994 |
Wheels & Tires |
Wheel size: |
front: 18-inch x 9.5-inch (std); 19-inch x 10-inch (w/ Z07 pkg.) |
Tires: |
front: 275/35ZR18 (std.); 285/30ZR19 (w/ Z07 pkg.) |
Dimensions |
Wheelbase (in / mm): |
105.7 / 2685 |
Overall length (in / mm): |
175.6 / 4460 |
Overall width (in / mm): |
75.9 / 1928 |
Overall height (in / mm): |
48.7 / 1236 |
Curb weight (lb / kg): |
3199 / 1451 |
Weight distribution (% front / rear): |
50 / 50 (Z06) |
Interior |
Seating capacity |
2 |
Interior volume (cu ft / L): |
52 / 1475 |
Headroom (in / mm): |
38 / 962 |
Legroom (in / mm): |
43 / 1092 |
Shoulder room (in / mm): |
55 / 1397 |
Hip room (in / mm): |
54 / 1371 |
Capacities |
Cargo volume (cu ft / L): |
22 / 634 |
Fuel tank (gal / L): |
18 / 68.1 |
Engine oil (qt / L): |
10.5 / 9.9 |
* SAE certified.
