Menu Navigation
2012 Corvette ZR1 Specifications
Below are specifications of the 2012 Corvette ZR1 including dimensions, engine, transmission, brakes, wheels and more.
Source:  GM Media
Model Lineup | Overview | Engines | Transmission | Chassis/Suspension | Brakes | Wheels/Tires | Dimensions | Capacities
Overview
Model:
Chevrolet Corvette ZR1
Body styles / driveline:
2-door hatchback coupe with fixed roof; rear-wheel drive
Construction:
composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components
Manufacturing location:
Bowling Green, Ky.
Back to top
Engines
6.2L SUPERCHARGED V-8 (LS9)
Displacement (cu in / cc):
376 / 6162
Bore & stroke (in / mm):
4.06 x 3.62 / 103.25 x 92
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
overhead valve, two valves per cylinder
Fuel delivery:
SFI (sequential fuel injection)
Compression ratio:
9.1:1
Horsepower / kW:
638 / 476 @ 6500*
Torque (lb-ft / Nm):
604 / 819 @ 3800*
Recommended fuel:
premium required
EPA-estimated fuel economy (city / hwy):
14 / 21
Back to top
Transmission
Tremec TR6060 close-ratio six-speed manual
Gear ratios (:1):
First:
2.29
Second:
1.61
Third:
1.21
Fourth:
1.00
Fifth:
0.82
Sixth:
0.68
Reverse:
3.11
Final drive ratio:
3.42
Back to top
Chassis/Suspension
Front:
short/long arm ( SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber
Rear:
Traction control:
electronic traction control; active handling (Magnetic Selective Ride Control)
Back to top
Brakes
Type:
front and rear power-assisted carbon-ceramic disc with 6-piston front and four-piston rear calipers, cross-drilled rotors; ABS std.
Rotor diameter (in / mm):
front: 15.5 / 394
rear: 15 / 380
Brake swept area
(sq in / mm):
front: 355 / 2290
rear: 309 / 1994
Back to top
Wheels/Tires
Wheel size:
front: 19-inch x 10-inch
rear: 20-inch x 12-inch
Tires:
Michelin Pilot Sport 2
front: P285/30ZR19
rear: P335/25ZR20
Back to top
Exterior
Wheelbase (in / mm):
105.7 / 2685
Overall length (in / mm):
176.2 / 4476
Overall width (in / mm):
75.9 / 1929
Overall height (in / mm):
48.7 / 1236
Curb weight (lb / kg):
3353 / 1521
Weight distribution
(% front / rear):
51 / 49
Interior
Seating capacity
2
Interior volume (cu ft / L):
52 / 1475
Headroom (in / mm):
38 / 962
Legroom (in / mm):
43 / 1092
Shoulder room (in / mm):
55 / 1397
Hip room (in / mm):
54 / 1371
Back to top
Capacities
Cargo volume (cu ft / L):
22 / 634
Fuel tank (gal / L):
18 / 68.1
Engine oil (qt / L):
10.5 / 9.9
Back to top
* SAE certified.
s
