Menu Navigation
2013 Chevrolet Corvette - Standard and Optional Equipment
Below is a listing of standard and optional equipment for the 2013 Corvette.
Safety & Security | Mechanical | Exterior | Interior | Seats | Entertainment Systems
Safety & Security
COUPE / CONVERTIBLE
GRAND SPORT COUPE / CONVERTIBLE
Z06 COUPE
ZR1 COUPE
Airbags — driver and passenger, dual-stage frontal with passenger detecting system airbag supression
S
S
S
S
Airbags — driver and passenger, seat-mounted side-impact
S
S
S
S
OnStar® In-Vehicle Communications and Assistance Service — includes 6 months of the Directions & Connections Plan with Turn-by-Turn Navigation* and OnStar RemoteLink™*
S
S
S
S
Safety restraints — 3-point belts for both seating positions with pre-tensioners and dual-mode retractors
S
S
S
S
Security system — content theft alarm, audible/visible
S
S
S
S
StabiliTrak® — Electronic Stability Control System
S
S
S
S
Theft-deterrent system — electronic immobilizer
S
S
S
S
Traction control — electronic, full-function, all-speed
S
S
S
S
Mechanical
COUPE / CONVERTIBLE
Z06 COUPE
ZR1 COUPE
427 Convertible Collector Edition — includes 505 hp 7.0L LS7 V8 engine with SFI, dry sump oil system, 6-speed manual transmission with short-throw shifter and launch control, carbon fibre hood with raised centre dome, grey metallic brake calipers, 19" x 10" front and 20" x 12" rear machined-face lightweight cup-style competition grey aluminum wheels, front P285/30ZR19 and P335/25ZR20 Michelin® Pilot® Sport Cup Extended Mobility Tires (EMT) and Magnetic Selective Ride Control suspension
O
Active Handling System — integrates chassis, brake and traction control systems
S
S
S
S
Axle — automatic transmission ratio (2.56:1)
O
Axle — automatic transmission ratio (2.73:1)
O
Axle — manual transmission ratio (3.42:1)
S
S
S
S
Battery — front-mounted
S
S1
Battery — on-board battery charger for long term storage
O
O
O
O
Battery — rear-mounted
S2
S
S
Battery — with run-down protection
S
S
S
S
Brakes — Power, 4-wheel vented discs
S
Brakes — 4-wheel Anti-lock Braking System (ABS)
S
S
S
S
Brakes — 4-wheel vented discs, Brembo® carbon ceramic cross-drilled rotors, 6-piston front calipers/4-piston rear calipers
O3
S
Brakes — 4-wheel vented discs, cross-drilled rotors, 6-piston front calipers/4-piston rear calipers
S
S
Brakes — painted brake calipers, Blue
S
Brakes — painted brake calipers, Grey Metallic
O4
O
O
Brakes — painted brake calipers, Red
O5
O4
S
O6
Brakes — painted brake calipers, Silver
O4,5
S
O6
O
Brakes — painted brake calipers, Yellow
O4,5
O4
O6
O6
Brakes — performance 340 mm front/325 mm rear cross-drilled rotors
O
Differential — cooling system
S6
S
S
Differential — rear limited-slip
S
S
S
S
Drive — rear wheel
S
S
S
S
Engine — 6.2L LS3 V8 with SFI; Horsepower — 430 @ 5900 rpm; Torque — 424 lb.-ft. @ 4600 rpm
S
S
Engine — 6.2L supercharged LS9 V8 with SFI; Horsepower — 638 @ 6500 rpm; Torque — 604 lb.-ft. @ 3800 rpm
S
Engine — 7.0L LS7 V8 with SFI; Horsepower — 505 @ 6300 rpm; Torque — 470 lb.-ft. @ 4800 rpm
O7
S
Engine — oil cooler
S
S
Exhaust system — aluminized stainless steel with 3" polished stainless steel tips
S
S
Exhaust system — performance dual mode with 4" polished stainless steel tips
O
O
S
S
Oil system — dry sump
S7
S
S
Steering — power assisted rack-and-pinion, speed-sensitive
S
S
S
S
Steering — power steering cooler
S
S
Suspension — 4-wheel independent, includes transverse composite leaf springs
S
S
S
S
Suspension — Magnetic Selective Ride Control®, computer-controlled active suspension system with adjustable shock absorbers, driver-selectable Tour and Sport modes
O8
O9
O10
S
Traction management — Performance Traction Management system with 5 driver-selectable settings
O3
S
Transmission — 6-speed automatic with steering-wheel-mounted paddle shifters
O
O11
Transmission — 6-speed manual with short-throw shifter and launch control
S
S
S
S
Transmission — oil cooler
S
S
Z06 Performance Package — includes power steering, axle and engine/transmission oil coolers, stiffer springs and stabilizer bars and specific shock absorbers
S
Z06 Ultimate Performance Package — includes Brembo® brakes with 6-piston front and 4-piston rear carbon-ceramic cross-drilled rotors, five-spoke cup style Black 19" x 10" front and 20" x 12" rear lightweight aluminum wheels, front P285/30ZR19, rear P335/25ZR20 Michelin® Pilot® Sport Cup Extended Mobility Tires (EMT), Magnetic Selective Ride Control suspension, Performance Traction Management system and Carbon Fibre Package (ordering restrictions apply, see your dealer for details)
O
Z16 Performance Package — includes heavy-duty cooling system, stiffer springs and stabilizer bars, specific shock absorbers, specific 6-speed manual transmission (if available 6-speed automatic transmission is ordered, package includes 2.73:1 performance axle ratio)
S
Z52 Performance Package — includes dry sump oil system, rear-mounted battery and differential cooler
S7
S
S
ZR1 High Performance Package — includes close-ratio 6-speed manual transmission, 19" x 10" front and 20" x 12" rear five-spoke cup style Black aluminum wheels, front P285/30ZR19 and rear P335/25ZR20 Michelin® Pilot® Sport Cup Extended Mobility Tires (EMT) and black painted full-width racing spoiler
O
ZR1 Performance Package — includes power steering, axle and engine/transmission oil coolers and stiffer springs and stabilizer bars
S
Exterior
COUPE / CONVERTIBLE
Z06 COUPE
ZR1 COUPE
427 Heritage Package — includes satin black hood stripes and special 427 embroidered floor mats
O
O
60th Anniversary Package — includes dark grey metallic brake calipers, ZR1-style rear spoiler, body-coloured door handles, Artic White exterior colour and exclusive Diamond Blue interior trim (includes Blue convertible top on Convertible models)
O
O12
O
O13
60th Anniversary Stripe Package — includes pearl silver blue dual full-length body stripes (tonal stitch stripes on Convertible tops)
O
O
O
O
Body panels — carbon fibre engine hood
O
S
Body panels — carbon fibre front fenders and floor
S
S
Body panels — corrosion-proof composite body panels
S
S
S
S
Body panels — raised engine hood with window, carbon fibre roof, roof bow, front splitter and rocker extensions
S
Convertible top — manual folding includes glass rear-window with defogger (Convertible models only)
S
S
Glass — Solar-Ray, tinted
S
S
S
S
Grand Sport Heritage Package — includes Fender Stripe Package and two-tone bucket seats with Grand Sport embroidered head rests (ordering restrictions apply, see your dealer for details)
O
Headlight Bezels — non-body coloured (available in black, blade silver metallic, and cyber grey metallic)
O
O
O
O
Lights — daytime running lights with automatic light control and Twilight Sentinel®
S
S
S
S
Lights — fog lights
S
S
S
S
Mirrors — heated, power remote control with driver's side auto-dimming feature
S
S
S
S
Roof Package — one-piece, transparent and standard body-colour roof panels
O
O
Roof Package — one-piece, transparent removable roof panel
O
O
Roof — one piece, body-colour removable roof panel
S
S
Spoiler — ZR1-style rear spoiler
O
O
O
O
Tires — front, P245/40ZR18 / rear, P285/35ZR19 — Goodyear® Eagle F1 Extended Mobility (EMT)
S
Tires — front, P275/35ZR18 / rear, P325/30ZR19 — Goodyear® Eagle F1 Supercar Extended Mobility (EMT)
S
Tires — front, P275/35ZR18 / rear, P325/30ZR19 — Goodyear® Eagle F1 Supercar G:2 Extended Mobility (EMT)
S
Tires — front, P285/30ZR19 / rear, P335/25ZR20 — Michelin® Pilot® Sport Cup Extended Mobility (EMT)
O8
O14
S
Wheels — five spoke Silver-painted aluminum (QG6) — front, 18" x 8.5" / rear, 19" x 10"
S
Wheels — five-spoke chrome aluminum (QX3) — front, 18" x 8.5" / rear, 19" x 10"
O
Wheels — five-spoke machined-face aluminum (RQ1) — front, 18" x 8.5" / rear, 19" x 10"
O
Wheels — 10-spoke spider-design chrome aluminum (Q8A) — front, 18" x 9.5" / rear, 19" x 12"
O
Wheels — 10-spoke spider-design Silver-painted aluminum (Q10) — front, 18" x 9.5" / rear, 19" x 12"
S
Wheels — 20-spoke Black-painted aluminum (Q6U) — front, 19" x 10" / rear, 20" x 12"
O
Wheels — 20-spoke chrome aluminum (Q6B) — front, 19" x 10" / rear, 20" x 12"
O
Wheels — 20-spoke Sterling Silver-painted aluminum (Q6A) — front, 19" x 10" / rear, 20" x 12"
S
Wheels — 5-spoke black painted aluminum (Q8B) - front 18" x 8.5" / rear, 19" x 10"
O
Wheels — 5-spoke cup-style black aluminum with red stripe (RUR) - front 19" x 10" / rear, 20" x 12"
O
O
Wheels — 5-spoke cup-style machined-face aluminum (Q5V) - front 19" x 10" / rear, 20" x 12"
O
O
Wheels — 5-spoke machined-face lightweight cup-style competition grey aluminum (Q8K) - front 19" x 10" / rear, 20" x 12"
O8
O
O
Wheels — Grand Sport 5-spoke black painted aluminum (QZW) - front 18" x 9.5" / rear, 19" x 12"
O
Wheels — Grand Sport five-spoke chrome aluminum (PYE) — front, 18" x 9.5" / rear, 19" x 12"
O
Wheels — Grand Sport five-spoke Silver-painted aluminum (PYC) — front, 18" x 9.5" / rear, 19" x 12"
S
Windshield wipers — 2-speed with variable delay (intermittent)
S
S
S
S
Z06 Carbon Fibre Package — includes black carbon fibre front splitter, rockers, roof bow and body-coloured ZR1 style rear spoiler
O
Interior
COUPE / CONVERTIBLE
Z06 COUPE
ZR1 COUPE
Air conditioning — automatic, dual-zone, with pollen filter, includes exterior temperature display
S
S
S
S
Console — with storage, auxiliary power outlet, fuel-filler door release, ashtray with cigar lighter, armrest and cupholders
S
S
S
S
Cruise control — steering-wheel mounted
S
S
S
S
Instrumentation — analogue speedometer, tachometer, fuel, voltmeter, coolant temperature and oil pressure gauges
S
S
S
S
Instrumentation — Driver Information Centre (multi-language), includes GM Oil Life Monitoring System and tire pressure monitoring system
S
S
S
S
Instrumentation — Head-Up Display (HUD), includes readouts for street mode, track mode with G-meter, vehicle speed, tachometer and key gauge readings
O
O
S
S
Locks — E-Z Key passive entry system includes push button start, lock/unlock passive entry and personalization with activation notification and panic feature
S
S
S
S
Locks — power, programmable with lock-out protection
S
S
S
S
Mirror — rear-view, with OnStar® controls, compass and auto-dimming feature
S
S
S
S
Steering column — manual tilt adjustable
S
S
S
S
Steering wheel — 3-spoke leather-wrapped with Bluetooth®, cruise and audio system controls
S
S
S
S
Universal home remote — 3-channel programmable remote transmitter
O
O
O
S
Windows — driver and passenger with express-down feature
S
S
S
S
Seats
COUPE / CONVERTIBLE
Z06 COUPE
ZR1 COUPE
Bucket seats with leather seating surfaces
S
S
Bucket seats with leather seating surfaces, contrasting stitching and model-specific embroidered headrests
S
S
Custom Interior Stitching Package — Features custom stitching on instrument panel, door trim, seats, centre console centre stack trim plate, transmission shifter boot and knob, and parking brake boot
O
O
O
O
Custom Leather-wrapped Interior Package — includes leather-wrapped upper instrument panel, upper door panels and console storage cover — features exclusive colours and two-tone design with crossed flag embroidery on head restraints and enhanced armrest padding
O
O
O
S
Heated bucket seats
O
O
O
O
Power 6-way driver seat adjuster
S
S
S
S
Power 6-way passenger seat adjuster
S
S
S
S
Sport bucket seats with perforated leather seating surfaces, power lumbar and side bolster adjusters
O
O
O
O
Two-tone modified bucket seats with perforated leather seating surfaces and crossed flag embroidered head rests and contrasting stitching
O
O
COUPE / CONVERTIBLE
Z06 COUPE
ZR1 COUPE
7-speaker premium audio system
S
S
S
S
All Corvette sound systems include an electronically tuned AM/FM stereo with CD player, MP3 playback compatability, seek up/down, scan, Radio Data System® (RDS), auto tone control, speed-compensated volume control, auxiliary audio input jack, TheftLock® and digital clock
S
S
S
S
Bluetooth® — hands-free phone connectivity
S
S
S
S
Bose® 9-speaker premium audio system
O
O
O
O
DVD Navigation System — with single disc CD player, 165 mm (6.5 in.) LCD colour display, touch screen, voice recognition, USB port, Bose® 9-speaker sound system‡ ‡
O
O
O
O
SiriusXM Satellite Radio™
S
S
S
S
S = Standard  O = Optional  — = Not Available
1 - Standard on Convertible and included with available automatic transmission on Coupe.
2 - Included with Coupe only, unless available 427 Convertible Collector Edition is ordered. Includes front mounted battery when available automatic transmission is ordered.
3 - Requires available Z06 Ultimate Performance Package.
4 - Requires available performance brakes.
5 - Not available with 60th Anniversary Package.
6 - Included with manual transmission equipped Coupe only, unless available 427 Convertible Collector Edition is ordered.
7 - Included with available 427 Convertible Collector Edition.
8 - Includes larger front and rear cross-drilled rotors.
9 - Includes Eagle F1 Supercar G:2 tires when manual transmission is ordered.
10 - Includes 5-spoke cup-style lightweight aluminum 19" x 10" front and 20" x 12" rear wheels with Michelin Pilot Sport Extended Mobility Tires.
11 - Includes 2.73:1 axle ratio. Deletes standard Z52 Performance Package on Coupe.
12 - Includes carbon fibre front splitter and cyber grey metallic headlight bezel when ordered with available 427 Convertible Collector Edition.
13 - Includes Michelin Pilot Sport Cup Extended Mobility Tires and black full-width racing spoiler when ordered with ZR1 High Performance package.
14 - Included with available Z06 Performance Package.
‡ ‡ At time of printing, detailed map coverage is available for most major urban areas of the United States and for certain metropolitan areas of Canada (Vancouver, Calgary, Edmonton, Winnipeg, Windsor, London, Toronto, Ottawa, Montreal, Quebec City and Halifax). Coverage is significantly limited outside these areas.
‡ Available in 10 Canadian provinces and the 48 contiguous United States. Subscription sold separately after trial period. Visit siriusxm.ca for details.
* Visit onstar.ca for coverage map, details and systems limitations. Services vary by model and conditions.
Source:  GM Media
