Below is a listing of preliminary specifications for the 2013 Corvette 427 Collector Edition:
2012-01-12
Source: GM Media
Overview |
Model: |
Chevrolet Corvette 427 Convertible Collector Edition |
Body styles / driveline: |
two-door convertible; rear-wheel drive |
Construction: |
composite body panels, hydroformed steel frame with aluminum and magnesium structural and chassis components |
Manufacturing location: |
Bowling Green, Ky. |
Engines |
7.0L V-8 LS7 (Z06) |
Displacement (cu in / cc): |
427 / 7008 |
Bore & stroke (in / mm): |
4.125 x 4 / 104.8 x 101.6 |
Block material: |
cast aluminum |
Cylinder head material: |
cast aluminum |
Valvetrain: |
overhead valve, two valves per cylinder |
Fuel delivery: |
SFI (sequential fuel injection) |
Compression ratio: |
11.0:1 |
Horsepower |
505 / 377 @ 6300* |
Torque (lb-ft / Nm @ rpm): |
470 / 637 @ 4800* |
Recommended fuel: |
premium required |
Estimated fuel economy |
15 / 24 (no guzzler tax) |
Transmission |
six-speed manual |
Application: |
std. |
Gear ratios (:1): |
First: |
2.66 |
Second: |
1.78 |
Third: |
1.30 |
Fourth: |
1.00 |
Fifth: |
0.74 |
Sixth: |
0.50 |
Reverse: |
2.90 |
Final drive ratio: |
3.42 |
Front: |
short/long arm (SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber; Magnetic Selective Ride Control |
Rear: |
Traction control: |
electronic traction control; Active Handling |
| Type: | front and rear power-assisted disc with ABS with six-piston front and four-piston rear calipers, cross-drilled rotors; |
| Rotor diameter x thickness (in / mm): |
front: 14 x 1.3 / 355 x 32 rear: 13.4 x 1 / 340 x 26 |
| Brake swept area (sq in / mm): | front: 309 / 1994 rear: 269 / 1735 |
Wheel size: |
front: 19-inch x 10-inch aluminum |
Tires: |
front: 285/30ZR19 |
Exterior
Wheelbase (in / mm): |
105.7 / 2685 |
Overall length (in / mm): |
175.6 / 4460 |
| Overall width (in / mm): | 75.9 / 1928 |
Overall height (in / mm): |
48.7 / 1236 |
Curb weight (lb / kg): |
3355/ 1522 |
Weight distribution |
50 / 50 |
Interior
Seating capacity |
2 |
Interior volume (cu ft / L): |
52 / 1475 |
Headroom (in / mm): |
38 / 962 |
Legroom (in / mm): |
43 / 1092 |
Shoulder room (in / mm): |
55 / 1397 |
Hip room (in / mm): |
54 / 1371 |
Cargo volume (cu ft / L): |
11 / 295 (top up); 7.5 / 212 (top down) |
Fuel tank (gal / L): |
18 / 68.1 |
Engine oil (qt / L): |
10.5 / 9.9 |
* SAE certified.
