Below is a listing of specifications for the 2013 Corvette ZR1, including dimensions, capacities and more.
Source: GM Media
Model: |
Chevrolet Corvette ZR1 |
Body styles / driveline: |
2-door hatchback coupe with fixed roof; rear-wheel drive |
Construction: |
composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components |
Manufacturing location: |
Bowling Green, Ky. |
| Back to top |
6.2L Supercharged V-8 (LS9) |
Displacement (cu in / cc): |
376 / 6162 |
Bore & stroke (in / mm): |
4.06 x 3.62 / 103.25 x 92 |
Block material: |
cast aluminum |
Cylinder head material: |
cast aluminum |
Valvetrain: |
overhead valve, two valves per cylinder |
Fuel delivery: |
SFI (sequential fuel injection) |
Compression ratio: |
9.1:1 |
Horsepower / kW: |
638 / 476 @ 6500 (SAE certified) |
Torque (lb-ft / Nm): |
604 / 819 @ 3800 (SAE certified) |
Recommended fuel: |
premium required |
EPA-est. fuel economy |
14 / 21 |
| Back to top |
Tremec TR6060 close-ratio six-speed manual |
Gear ratios (:1): |
First: |
2.29 |
Second: |
1.61 |
Third: |
1.21 |
Fourth: |
1.00 |
Fifth: |
0.82 |
Sixth: |
0.68 |
Reverse: |
3.11 |
Final drive ratio: |
3.42 |
| Back to top |
Front: |
short/long arm ( SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber |
Rear: |
Traction control: |
electronic traction control; active handling (Magnetic Selective Ride Control) |
| Back to top |
Type: |
front and rear power-assisted carbon-ceramic disc with 6-piston front and four-piston rear calipers, cross-drilled rotors; ABS std. |
Rotor diameter (in / mm): |
front: 15.5 / 394 |
Brake swept area |
front: 355 / 2290 |
| Back to top |
Wheel size: |
front: 19-inch x 10-inch |
Tires: |
Michelin Pilot Sport 2 |
| Back to top |
Exterior
Wheelbase (in / mm): |
105.7 / 2685 |
Overall length (in / mm): |
176.2 / 4476 |
Overall width (in / mm): |
75.9 / 1929 |
Overall height (in / mm): |
48.7 / 1236 |
Curb weight (lb / kg): |
3353 / 1521 |
Weight distribution |
51 / 49 |
Interior
Seating capacity |
2 |
Interior volume (cu ft / L): |
52 / 1475 |
Headroom (in / mm): |
38 / 962 |
Legroom (in / mm): |
43 / 1092 |
Shoulder room (in / mm): |
55 / 1397 |
Hip room (in / mm): |
54 / 1371 |
| Back to top |
Cargo volume (cu ft / L): |
22 / 634 |
Fuel tank (gal / L): |
18 / 68.1 |
Engine oil (qt / L): |
10.5 / 9.9 |
| Back to top |
