A general listing of 1969 Corvette Identification Numbers including engine block, head id, casting numbers and more:
| Engine Suffix ID Numbers |
| GC: |
350ci, 350hp (manual transmission, transistor ignition) |
| GD: |
350ci, 350hp (air conditioning, manual transmission, transistor ignition) |
| HW: |
350ci, 350hp (manual transmission) |
| HX: |
350ci, 350hp (air conditioning, manual transmission) |
| HY: |
350ci, 300hp (manual transmission) |
| HZ: |
350ci, 300hp (automatic transmission) |
| LL: |
427ci, 390hp (automatic transmission) |
| LM: |
427ci, 390hp (manual transmission) |
| LN: |
427ci, 400hp (automatic transmission) |
| LO: |
427ci, 430hp (L88) (manual transmission) |
| LP: |
427ci, 435hp (aluminum heads, manual transmission) |
| LQ: |
427ci, 400hp (manual transmission) |
| LR: |
427ci, 435hp (manual transmission) |
| LT: |
427ci, 435hp (heavy duty clutch, manual transmission) |
| LU: |
427ci, 435hp (aluminum heads, heavy duty clutch, manual transmission) |
| LV: |
427ci, 430hp (L88) (automatic transmission) |
| LW: |
427ci, 435hp (aluminum heads, automatic transmission) |
| LX: |
427ci, 435hp (automatic transmission) |
| ME: |
427ci, 430hp (ZL1) (manual transmission) |
| MG: |
427ci, 430hp (ZL1) (automatic transmission) |
| MH: |
427ci, 390hp (manual transmission, transistor ignition) |
| MI: |
427ci, 390hp (automatic transmission, transistor ignition) |
| MJ: |
427ci, 400hp (automatic transmission, transistor ignition) |
| MK: |
427ci, 400hp (manual transmission, transistor ignition) |
| MR: |
| MS: |
427ci (unknown use) |
| Carburetor ID Numbers |
| Rochester Q-jet #7029202: |
| Rochester Q-jet #7029203: |
| Rochester Q-jet #7029204: |
| Rochester Q-jet #7029207: |
| Rochester Q-jet #7029215: |
| Holley R3659A #3902353: |
427ci, 400hp (front carburetor, rear carburetor), 435hp (front carburetor, rear carburetor) |
| Holley R4055-1A #3940929: |
427ci, 400hp (center carburetor, manual transmission), 435hp (center carburetor) |
| Holley R4056-1A #3940930: |
427ci, 400hp (center carburetor, automatic transmission) |
| Holley R4054A #3925519: |
427ci, 430hp (first design) |
| Holley R4296A #3955205: |
427ci, 430hp (second design) |
| Identification |
Exterior:
- Seven inch, silver painted wheels were unique to the 1968 model year..
- Unique to the 1968 model year was a special door opening system that consisted of a separate release button and a spring-loaded finger plate.
- The side gills on the 1968 Corvette did not come with the chrome inserts which were an option on the 1969 model year.
Interior:
- This was the first year for a new cabin ventilation system called "Astro-Ventilation", windshield wipers that were hidden under a vacuum-actuated door panel at the base of the windshield, and a special fiber-optic light monitoring system.
Exterior Emblems:
- Model Years: 1968 - 1969
- Description:
- This hood with the 427 emblem was only used with the L36, L68 and L71 427ci engine options for 1968 and 1969.
Trim Tag:
- Description: This contains factory ordered color and trim option codes.
- Location: The Trim Tag is located on the driver's door hinge pillar.
