Menu Navigation
2011 Corvette Z06 Specifications
Below is a complete listing of specifications for the 2011 Corvette Z06.
Source:  General Motors
Model Lineup | Overview | Engines | Transmission | Chassis/Suspension | Brakes | Wheels/Tires | Dimensions | Capacities
Model Lineup
Engine
Transmission
7.0L V-8 (LS7)
6-spd. manual
Corvette Z06
s
s
Key
Standard
s
Back to top
Overview
Models:
Chevrolet Corvette Z06
Body styles / driveline:
two-door hatchback coupe with fixed roof; rear-wheel drive
Construction:
composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components
Manufacturing location:
Bowling Green, Ky.
Back to top
Engines
Displacement (cu in / cc):
427 / 7008
Bore & stroke (in / mm):
4.125 x 4 / 104.8 x 101.6
Block material:
cast aluminum
Cylinder head material:
cast aluminum
Valvetrain:
overhead valve, two valves per cylinder
Fuel delivery:
SFI (sequential fuel injection)
Compression ratio:
11.0:1
Horsepower
(hp / kW @ rpm):
505 / 377 @ 6300*
Torque (lb-ft / Nm @ rpm):
470 / 637 @ 4800*
Recommended fuel:
premium required
EPA estimated fuel economy (city / hwy):
15 / 24 (manual)
Back to top
Transmission
Application:
std.
Gear ratios (:1):
First:
2.66
Second:
1.78
Third:
1.30
Fourth:
1.00
Fifth:
0.74
Sixth:
0.50
Reverse:
2.90
Final drive ratio:
3.42
Back to top
Chassis/Suspension
Front:
short/long arm (SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber; Magnetic Ride Control w/ Z07 pkg.
Rear:
Traction control:
electronic traction control; Active Handling
Back to top
Brakes
Type:
front and rear power-assisted disc with ABS with six-piston front and four-piston rear calipers, cross-drilled rotors; ceramic rotors w/ Z07 pkg.
Rotor diameter x thickness (in / mm):
front: 14 x 1.3 / 355 x 32
rear: 13.4 x 1 / 340 x 26
Brake swept area
(sq in / mm):
front: 309 / 1994
rear: 269 / 1735
Back to top
Wheels/Tires
Wheel size:
front: 18-inch x 9.5-inch (std); 19-inch x 10-inch (w/ Z07 pkg.)
rear: 19-inch x 12-inch (std); 20-inch x 12-inch (w/ Z07 pkg.)
Tires:
front: 275/35ZR18 (std.); 285/30ZR19 (w/ Z07 pkg.)
rear: 325/30ZR19 (std.); 335/25ZR20 (w/ Z07 pkg.)
Back to top
Exterior
Wheelbase (in / mm):
105.7 / 2685
Overall length (in / mm):
175.6 / 4460
Overall width (in / mm):
75.9 / 1928
Overall height (in / mm):
48.7 / 1236
Curb weight (lb / kg):
3175 / 1440 (Z06)
Weight distribution
(% front / rear):
50 / 50 (Z06)
Interior
Seating capacity
2
Interior volume (cu ft / L):
52 / 1475
Headr oom (in / mm):
38 / 962
Legroom (in / mm):
43 / 1092
Shoulder room (in / mm):
55 / 1397
Hip room (in / mm):
54 / 1371
Back to top
Capacities
Cargo volume (cu ft / L):
22 / 634
Fuel tank (gal / L):
18 / 68.1
Engine oil (qt / L):
10.5 / 9.9
Back to top
* SAE certified.
